TwinTurbo.NET: Nissan 300ZX forum - SPL-KTS Coilover changing springs
Subject SPL-KTS Coilover changing springs
Posted by ZonaZ on April 23, 2011 at 2:01 PM
  This message has been viewed 216 times.
Message after talking to Kuah I am changing my springs, basically moving the front 8kg/mm to the rear and installing 10kg/mm on the front.
To put the new springs on do I just loosen the spring perch, lock nuts and screw the lower bracket off? Can I do this on the Z? No spring compressors necessary?
The standard front springs are 8" preloaded to 7". Kuah recommended 7" for the front, do I need to preload them at all or just tension the spring perch to the spring leaving it at 7" basically?
thx for any help
